Online:
WideglidingNZ
Mirrors
Mirrors
robinhood_52
4 months
I have a 100th aniversary custom 1200 sportster, and since I bought it I have replaced both mirrors numerous times due to them breaking off where the thread stops due, I assume, to metal fatigue, and vibration. Is there some way to lessen the vibration.
4 months
odd... is it a efi rubber mount motor or solid mount? if its rubber mount then something is definitely not right.
robinhood_52
4 months
Yes, solid mount. I've been told about soft mount kit for risers, but can't find anywhere.
robinhood_52
4 months
Just found neoprene spacers on ebay.
Will update later. Thanks
© 2024, v3.1.0
