m8 slipping clutch
m8 slipping clutch
ga121
5 months
Hi, have a 10/18 cvo streetglide 40000klm .Clutch has started to slip after last ride. Changed oil still the same. Anyone experienced the same.Thanks. Gary
5 months
Change the clutch springs for heavy duty ones.
5 months
The clutch could be worn/damaged .
Has it been adjusted correctly ?
How dark was the oil ?
Any burnt smell ?
If you've caught it in time, heavier springs might be the fix.
Baloffski likes this post
WideglidingNZ
5 months
What oil are you using in the primary? then check clutch and cable adjustment, you can get heavier clutch springs(SE 1275lb's) as Pauly said, although once they start slipping you may need new fibre plates
© 2024, v3.1.0
