03 Softail header pipes
  • Stewy
    Stewy
    8 months
    Wanted to buy
    G'day,, I'm looking for header pipes for 00-06 softail, I think they are all the same,,,
    Needed to fit 02 nightrain
    Thanks
  • Retroman
    7 months
    I reckon you'd be right with 2007 to 2017 stock headers, just with "blanking bolts" in the O2 sensor holes.
    That would for sure make your search easier, especially if you get the whole system including brackets and bolts.
  • keith
    keith
    7 months
    Quoting Retroman on 13 Sep 2023 01:12 PM
    I saw this post the other day and was thinking the same Retro,@ Stewy attached pics of what you're chasing? trip to Bunnings for 02 bungs and should be right, I'm in Perth some maybe the curved ball for you? PM me if you are interested. Cheers.
  • Stewy
    Stewy
    7 months
    Yeah, thanks gentlemen,, that's just what I did, found a system complete with brackets and bolts , just had to get gaskets,, too easy,, bolted straight on. It had never been used, taken off when new , and a good price .
