Online:
BLKOPS
Screaming eagle
Screaming eagle
Dannyfatbob114
9 months
Just got myself a fatbob it has a screaming eagle heavey breather elite air cleaner
It's in the way for me being taller, what would you guys suggest to switch it to? And would anyone here like the old one? What would it be worth?
Need to switch
Grease Monkey
9 months
The HD Ventilator is a lower profile decent filter if you want to stay with SE stuff or there are shit loads of decent options from the aftermarket, sorta depends on your taste, S&S make improved versions of their old teardrop style if that look takes your fancy, plus they don't stick out too far.
Dannyfatbob114 and WideglidingNZ like this post
diomac
9 months
Mate to be honest I think the Ventilator is about as low profile as they come. I think changing it out wouldn’t help you much.
WideglidingNZ
9 months
Just some other non HD options that I've been looking at for my LRS-
https://rolliesspeedshop.com/shop/fuel-air-systems/air-cleaner-kits-components/trask-performance-assault-clear-air-cleaner-kit-gloss-black-fits-touring-2017up-softail-2018up/
https://rolliesspeedshop.com/shop/fuel-air-systems/air-cleaner-kits-components/milwaukee-eight-17up/feuling-ba-air-cleaner-kit-black-with-clear-cover-fits-touring-2017up-softail-2018up
https://rolliesspeedshop.com/shop/fuel-air-systems/air-cleaner-kits-components/ss-air-stinger-stealth-air-cleaner-kit-black-teardrop-fits-milwaukee-eight-2017up/
these air cleaners should out perform any SE stuff, I'm not affiliated with Rollies I just find their web site useful for finding parts
9 months
Bloody nora... nearly a grand for just an air cleaner! im in the wrong business.
Grease Monkey and WideglidingNZ like this post
Dannyfatbob114
9 months
Yeah it was on it when I brought it, I looked it up and thought geezers !!!!!!
Seeing how expensive they are I wana make the right choice so I don't have to do it again. As long as it's not as stick out itl be good most are that oval ish shape like stock and that's much better fit I think you could only run this one if u had mid controls or were really short lol
Dannyfatbob114
8 months
Cheers ill check it out conversion to aus dollar is roughly double most of the time.
© 2024, v3.1.0
