Dead bike
Dead bike
fathee01
10 months
Hi,lm looking for an answer to what I have fried on my 01 fat boy. I took the positive lead off the battery first and in doing so touched the frame with a screwdriver.I reconnected and it is dead power wise. What do I need to replace?
Grease Monkey
10 months
Fuse or the like? Battery ok?
tussuck likes this post
10 months
+ve to the frame should in theory blow your main fuse. NFI were it is located on your model, but thats the starting point (Check all the fuses as it could have taken out more than 1)
brucefxdl likes this post
10 months
You've obviously checked fuses before asking here ?
In theory , shorting battery positive to frame shouldn't blow a fuse.
It may spike your regulator or ignition module though .
I think the 01 would have a main resettable breaker.
Grease Monkey likes this post
Grease Monkey
10 months
My 96 sporty had a self resetting breaker, sometimes it needed a tap until I changed it, have seen batteries give up the ghost from a quick short, not the norm but if it's on its way out that can be enough to finish it.
10 months
FYI wiring diagram - click link below
2001 wiring
fathee01
10 months
Cheers to you blokes
© 2024, v3.1.0
