91 FXSTC
91 FXSTC
robbo200
10 months
I’m at my wits end the Jack shaft won’t move across far enough to engage
with the ring gear on the clutch basket I’ve replace worn bits in solenoid replaced Jack shaft with a one piece all ball racing one still the same problem. The only thing I can replace now is the starter motor any help would be great
10 months
Was the solenoid plunger the same length as the original one you
Pulled out as some of the repair kits come with a shorter length
For sportsters not big twin other wise maybe starter clutch
Inside the nose cone is worn out most of the parts are the same as
Toyota 80s cars Nippon denso , good luck
robbo200
10 months
The plunger is the same size when you say stater clutch is that a part actually inside the starter motor
Thanks for you help bro
10 months
Yes it’s in the nose cone of the starter so you will have to remove the whole starter motor
Which is a pain in the arse You can get it out with oil tank still in the bike just take battery out
And undo the mount bolts for the oil tank so it can move a bit , or just take the tank completely out
The two starter bolts are pain to get at normally capscrews , you’ll have to take primary cover and
Jackshaft out two , just a thought how old/ charged up is your battery
robbo200
10 months
Thanks I got it sorted end up getting a new starter and I will rebulid the old and keep it as a spare
Grease Monkey
10 months
What was wrong Robbo? Was it blocked up in the throwout shaft space?
robbo200
10 months
When I put the 2 starter side buy side and push the button mounted on the solenoid the new starter motor spline pushed out all the way where as the old one only moved about half so not sure why something to do with stater clutch inside the nose cone
10 months
I could wrong but I think the starter clutch is on the armature side of the starter that may not affect the throw plunger side , was the push button
On the old starter firm to push in about the same as the new one
robbo200 likes this post
Grease Monkey
10 months
This is very tempting in this situation 😂
© 2024, v3.1.0
