Online:
beaglebasher, baldy1450, Hilly
2011 rear wheel
2011 rear wheel
Sed8td
10 months
Hi, I have a 2011 Softail standard with the factory rear solid wheel, I purchased a 18 X 5.5 fat spoke to match the front fat spoke, but I have a feeling I brought one that won't fit.
I have what I believe 25mm rear axle and the wheel has bearing for a 19mm axle.
The hub sizes are also different size.
Do I need to source another wheel or is it a case of buying the correct bearings for my 25mm axle?
John.R
10 months
If the outer diameter of the bearings is 52mm you can swap.
Sed8td
10 months
Thanks, I'll check tomorrow. But I don't like my chances
John.R
10 months
If it's running a normal harley sealed bearing rather then a timken, you can buy them in 3/4in, 1in and 25mm.
Sed8td
10 months
It's a 45mm hub.
Can I buy a bearing to suit a 25mm axle?
Grease Monkey
10 months
How wide does it need to be? 25mm x 45mm X ?mm, also are you absolutely sure of the 45mm measurement? Could be an imperial hub. If you could double check the 45mm it might be a bit over, 45.something.
John.R
10 months
Quoting Sed8td on 08 Jul 2023 11:18 PM
It's a 45mm hub.
That looks like the evo style timken bearing, tapered roller bearing and race, and the seal on the outside.
I don't beleive you'll get a 1in bearing for it, the inner and outer ID means the actual rollers would be tiny.
Grease Monkey
10 months
Fair call, 45 - 25 doesn't leave much for rollers and races.
John.R
10 months
I know of someone that found some (sealed 1in to fit timken size hole) online or a bearing shop, but they blew within a couple hundred kms.
Grease Monkey likes this post
Sed8td
10 months
Probably be even harder as I'll need ABS bearings too
Sed8td
10 months
Looks like I'll sell wheel and find a suitable one
Grease Monkey
10 months
That's probably your best bet mate 👍
Sed8td likes this post
STEAMER
10 months
Quoting Grease Monkey on 09 Jul 2023 02:33 AM
Wrong diameter,
2011 fxst is 17 inch
John.R
10 months
This popped up here in Canberra FYI. 25mm axle too, 18x5.5
Sed8td
10 months
Cheers, but I need a chrome one to match the front 😭
© 2024, v3.1.0
