Losing all electrics on a 98 fatboy.
beehappier
11 months
Hi, I have a 98 fatboy that is playing up. The ignition lights are okay for a while when I am starting it up. It normally takes a few goes to get it running but the lights go out and it won't crank over.
I thought it was the ignition switch but it wasn't. I don't really want to take it out for a ride while it's randomly dying on me.
Any common 98 fatboy problems in this area?
Thanks.
Rick.
11 months
Have you had the battery load tested? If that’s ok I’m not sure if a 98 do but early do thay have circuit breakers under the dash / ignition switch plate between the tanks
You might have a dicky one + clean your main earths and battery power connections or a dicky kill switch
good luck
beehappier
11 months
Thanks mate.
© 2024, v3.1.0
