Online: Hilly, pat
New CVO's
  • Grease Monkey
    Grease Monkey
    7 months
    Quoting Grease Monkey on 20 Sep 2023 06:29 AM
    Clip of it on the dyno.....
    Quoting WideglidingNZ on 20 Sep 2023 07:48 AM
    I thought they would have been over 110hp and 120 ftlb's of torque I wonder what upgrades would be possible with the VVT I imagine it would make changing/finding a cam difficult?
    Same, the torque was less than advertised but maybe HD measure it at the crank? without the speed limiter in play the HP would be higher, limiter kicks in at 110MPH if what I've read is right, you can see on his dyno screen that even in 4th gear it cut out just above the 5250RPM cross over, torque was still up there and although it was on the way down with more RPM the HP would climb a bit more, aftermarket will get cams happening but tuning them might be an issue, might have to revert to the old PVIIIUSB days 😁
  • 408
    408
    7 months
    and think about pulling the fairing off it
  • Grease Monkey
    Grease Monkey
    7 months
    Nasty things fairings 😁👍
  • 408
    408
    7 months
    Ok, might have to start a gofundme
    7 months
  • Grease Monkey
    Grease Monkey
    7 months
    Thanks for that vid Speedzter, I will watch that tonight on the big screen, should entertain the missus no end lol
