SE Pro Tuner Base Maps
  • 408
    408
    1 year ago
    I have the SE software on a laptop but it is not going at the moment and I haven't used it enough to remember.
    Like Retroman said, there should be a toggle switch/button for ACR which you set at enabled/disabled or on/off.
    It is an option in the cal, you should not have to pick another one.
  • Grease Monkey
    Grease Monkey
    1 year ago
    Pappa, open the cal, go to tuning set up, working, top bar at far right click on acr, toggle enable, save it.
  • 408
    408
    1 year ago
    Quoting Grease Monkey on 10 Mar 2023 09:56 PM
    Ahhhh, you're out of bed  :)
  • Grease Monkey
    Grease Monkey
    1 year ago
    Quoting 408 on 10 Mar 2023 10:00 PM
    Yep, had to get on the puta for tax stuff and seen his post haha
  • PappaSmurf
    PappaSmurf
    1 year ago
    Thanks guys, I found it and enabled it, YeeHa. Now that I’m in Tuning Setup, Working I’ve noticed that the Temperature Management and Active Intake are disabled. As I don’t spend a lot of time idling I can leave the Temp Manage off, but can’t find any info on the Active Intake. Any ideas?
  • PappaSmurf
    PappaSmurf
    1 year ago
    I Found this, so I'll leave the AIS disabled.
    Harley used the Active Intake System (AIS) on 2007 Touring and 2007 thru 2015 Dyna & Softail and the Active Exhaust System (AES) on the European 2007 thru 2016 Dyna & Softail to comply with the latest EU noise emission regulations. The AIS creates a problem for those who want to install an aftermarket air cleaner as removal of the air cleaner back plate will cause the AIS to light a "Fault" warning light on the dash
  • Retroman
    1 year ago
    Yes, sorry I shoulda said. In the Tuning constants you toggle off the "Active air" and Active exhaust if they are not toggled off already.
    Some cals they are ON others OFF so best to check. I put them off on everything. I also put off the Idle temp' management.
    We in Australia got the "Euro" spec bikes by default. In late 2006 when the first 2007 models arrived in Perth WA , Frasers did not know what all that Active air and Active exhaust was. I found out from an HD dealer in Scotland what it was and how to manually fuck it off some years before before I could laptop switch it off.
  • Grease Monkey
    Grease Monkey
    1 year ago
    Yo Pappa, how goes it mate? there are no dumb questions, fire away if you need to, pm me if you want to chat on the phone.
  • PappaSmurf
    PappaSmurf
    1 year ago
    Hey Grease Monkey
    All going good now, I'll run it through the MyTune program wheni get back from the mainland. all i have to do now is an oil change on the transmission and primary. thanks for asking, I may take you up on your offer for a phone chat when i get back.
  • Baloffski
    Baloffski
    1 year ago
    Just dropped in on this thread. Thanks for starting PapaSmurf, and once again thanks Grase Monkey, and Retro. Has been a while since I smoothed my tune, as has been getting too much fuel of late, can smell it when stopped. I've been scratching my head today, and saw this, good shit. As Dyno $150 an hour, nah not today. Still have the old2012 Road Glide Tourer 103, V & H ovals and SE air cleaner with 204 cams . Had the 044sdH004.  but did not see 358scv002, will give that baby a go. 'Big bore' I ignore as don't know what it refers too. Thanks blokes .Sorry to drop in on ya Papa.
    Ah just remembered the 358.... is for Dyna, I better stick to my 044......
  • PappaSmurf
    PappaSmurf
    4 months
    Hi all, well it’s time to run the tuner through the bike again as I’m getting a bit of decel pop.
    My question is this. Do I start with the original base map I used, or do I use the final map, which is the one that’s in cpu at the moment.
  • Baloffski
    Baloffski
    4 months
    Very good question PS
    Grease Man , your on. I ain’t got nothing to reflect, PS. I would think restart with ya final readings and refine. But man Past few months  ….Wouldn’t wanna bum steer ya.
  • Grease Monkey
    Grease Monkey
    4 months
    The latter, if you haven't changed anything since the cal was put in just reflash it to clear all the learned stuff, if it clears it up then start looking for what drove it south.
  • PappaSmurf
    PappaSmurf
    4 months
    Thanks guys, I’ll start with the map I last installed and see how it runs. I’ve just done a full service on it, but now I’m thinking of changing my air filter system, so I’ll probably wait until after that’s installed.
