Online:
Humbug, beaglebasher, Hilly
Engine noise
Engine noise
Bones
1 year ago
hi guys can you tell me what your thoughts are on this ticking noise, i think i know but would like your opinion thanks.
please follow this link
https://youtube.com/shorts/0otogBxgDko?feature=share
Stewy
1 year ago
Sounds like exhaust flange, where it bolts to the head,, loose or a fucked gasket
Bones likes this post
1 year ago
Blown head gasket maybe?
bloodog
1 year ago
A mate has just had similar and was transmission mount needed a twitch up
1 year ago
Or loose flux capacitor....
B0nes likes this post
Grease Monkey
1 year ago
What year? There is a couple of ticks, one is the throttle body, normal, the other higher pitched one would have me checking the lifters if it's not an exhaust gasket, sounds metallic to me in the vid so cut oil filter open an check for metal, pronto.
Bones, obisteve and Uncle Chougs like this post
Grease Monkey
1 year ago
This is a 110 twin cam, nowhere near stock but you can hear the TB and the normal TC valve train symphony minus the tick in yours, if it's a lifter you need to address it now before it fails completely.
Grease Monkey
1 year ago
https://youtube.com/shorts/1SOGKqRXiEk?feature=share
Soapbox2627
1 year ago
try the rear bracket that holds the exhaust on
Jay-Dee
1 year ago
These videos always make it hard to tell for sure without being there, but even with headphones to me it sounds like exhaust.
speedzter likes this post
beaglebasher
1 year ago
I am getting a bit deaf but it sounds like the giggling pin is coming loose and is knocking on the laughing shaft .
Uncle Chougs
1 year ago
Hey Bones,yep it's a bit hard to accurately pin point the noise because it's a video,however here's an "old school" mechanics tip you could try,very useful and you don't need expensive tools at all,that will help you to "zoom in"on the noise location!
Get a very long screwdriver,put the tip of the screwdriver on the area or on top of the closest bolt you think the noise might be coming from,you then use the other side of the screw driver to listen to the noise(just as if you would have a stetoscope) then compare the different area you think the noise might be coming from,where it's louder it will be the area the problem is coming from...
I would start at the lifters as Grease Monkey suggested it also seems to me, after watching the video a few times,that it could be on the lifters side however the engine seems to idle normally but check anyway to be on the safe side...
Let us know the outcome...
bloodog likes this post
© 2024, v3.1.0
