Online:
softfat
Battery and starting issues
Hori
2 years ago
Hey guy im new here i have a 2011 dyna wide glide the battery charge when tested with a multimeter reads 12.85 volts but still won't crank the bike up cranks once or twice then click click click any of you guys had this problem i haven't checked the earth or positive terminals to starter yet
John.R
2 years ago
Voltage drop.
Im guessing that 12.85v is measured under zero load.
Measure it while cranking and you'll see why it doesn't have the juice.
Replace battery.
Grease Monkey, robnicko and flstc08 like this post
taff60
2 years ago
Check battery terminals, but it is probably a dead cell. Get it load tested. Batteries dont last that long.
flstc08 likes this post
robnicko
2 years ago
i had exactly the same issue with my battery two weeks ago despite being on a trickle charger
12.8v with zero load , 4.5v when trying to crank & click click click
had it load tested and 110cca.....
bought a Deka ETX20L and all good. load tested at shop and despite needing a charge (12.3v) cause it was sitting idle on the shelf tested @380cca
charged for a couple of hours before putting in bike and fired up instantly and 14.3v when measured running - i never recall it cranking over so strongly before
old battery is going to be used with a small solar panel for garden lighting now!
Baloffski likes this post
© 2024, v3.1.0
