Online:
Hilly
Replacement battery for 2013 Dyna FatBob
garman63
3 years ago
My OEM battery died recently and unfortunately local HD shop didn't have any in stock! Got a
MBTX20UHD 12V Motobatt Battery for $220 which has a CCA of 310. Feels a bit undercooked when trying to start the bike. Any opinions on a SSB YTX20L-BS AGM Battery with a CCA of 450 which I can get online from Vic (I'm in Wa) for about $170? Any others that might be suggested?
skirtster
3 years ago
Have a look at ssb web site they will have a list of batteries and specifications to suit your bike. deka make harley batteries, yuasa make good batteries.
garman63 likes this post
garman63
3 years ago
Sorry, not the lithium battery, the brand is SSB! Will wait for a couple of years to see what people using the lithiums reckon!
Chester likes this post
Ratbob
3 years ago
I just installed an SSB and the extra CCA sure make a difference in my 110.
garman63 and STEAMER like this post
potluk
3 years ago
i get mine from battery world. they even install it for me. make sure leads are tight your bike can run very bad if they are loose
STEAMER
3 years ago
Batteries Direct at Peakhurst nsw. Buy online.
Am sure its 330cca or more.
$139, plus free postage
Vic
3 years ago
If your going ssb Garman, give goodchilds a ring.
Very good on price , they're in cockburn Central.
3 years ago
Quoting garman63 on 07 Nov 2020 04:09 AM
SSB , good!!
I had a problem with one, but they start my motor so easy, I got another one & no problems, they are good! ( I can't remember the price so no help there sorry )
© 2024, v3.1.0
