Tyre pressures Bridgestone Battlecruise H50 2013 FatBob
  • garman63
    garman63
    3 years ago
    Greetings from Perth. Have just replaced OEM Dunlops with 130/90 16 and 180/70 16 with similar sized H50's. Wondering what pressures you are running with. The OEM'S are 36 and 40 and I notice Max PSI on these are about 41 cold. Haven't found any recommendations so am running at 34 front and 36 back for the moment. All suggestions welcome! Cheers
  • JFE
    JFE
    3 years ago
    Quoting garman63 on 04 Oct 2020 06:52 AM
    I’ve always been happiest with 38 front, 38 rear on my Fatbob (both OEM and now Avon Cobra’s).
  • Ratbob
    Ratbob
    3 years ago
    Quoting JFE on 05 Oct 2020 05:40 AM
    Yep, same pressures on mine.
  • garman63
    garman63
    3 years ago
    Thanks. Will try 38/ 38
  • beaglebasher
    beaglebasher
    3 years ago
    I can be a bit lazy when it comes to checking tyre  pressures so I usually blow both of them up to 40 psi.
    My thinking is within 10 %  either way is no big deal so if I forget to check them for a while I should hopefully still be within that 10% range.
    That theory should work if you check your tyres every couple of months.
    I do the same with the car but you know how time fly's.  Last time I checked  they were all under 30 psi and the lowest was 23 psi.
  • Baloffski
    Baloffski
    3 years ago
    Ma Statesmans and GTS's and the Old ZC Fairlaines 40 PSI as constant.
    Harley front 36 rear 38 , seems to work .
  • dicko
    dicko
    3 years ago
     I usually use 36/38 when cold ,and i have checked them on longer rides when hot, and they go up another 2 pounds. That,s for the standard dunlops.405
    On a road king
  • Wideglider
    Wideglider
    3 years ago
    Tyre pressures are the single most important regular maintenance safety check you should do, especially on two wheels. Check mine once a week.
    Go with the bike's recommendation tyre pressure - whilst not exceeding pressure stated on tyre sidewall.
  • brucefxdl
    brucefxdl
    3 years ago
    same WG,check tyre pressures less than a day prior to a ride,pressures seem to hold well but still check [ and wifes bikes well ]along with oils ect.
  • garman63
    garman63
    3 years ago
    Thanks again for all the input blokes! Tyres well and truly scrubbed in, will experiment a little with different pressure.
