Mate, if it's only the indicators I'd be looking at a bad connection on your indicator relay. If it involves other electrics aswell then I'd be looking for a bad earth on the battery or main earth connection to frame. A high resistance electrical connection can give these intermittent problems. Good luck & let us know if you find the answer.
Roo.
