INJECTOR CLEANER
  • 2005 FLSTFI
    2005 FLSTFI
    Anybody on here use injector cleaner in their bike.
    How often
    What type
    How much do you use at any one time.
    thanks for any input in advance.
    PS: Any queenslanders reading this, stay safe will ya's
  • AJ56
    AJ56
    Morey's Upper Cylinder lubricant. Few squirts in the tank every so often. Whether it is maintaining clean injectors is another matter . I put some in my daughters car when she bought it as it had injector noise and it cleaned them out and got rid of the noise. So it must be ok.
    Depending on how many K's your bike has done will depend on how dirty they are I suppose.
  • Dicey
    Dicey
    How do injectors get dirty? Isnt it high pressure fuel going through them?? How does that now keep them clean?
  • AJ56
    AJ56
    Carbon deposits, petrol is not that clean
  • 2005 FLSTFI
    2005 FLSTFI
    Thanks for your input guys
    Moreys, Lucas, Redline etc, basically all the good quality brands it is then
  • Lastrain
    Lastrain
    Thanks DuHast, 500:1 = 2ml per litre, that should be a little bit easier to measure and remember.
    Will probably try it in the cage first, the bike has only got 10,000 km's on it so probably fairly clean still, I do plan on using it as a preventative though and am planning a big bore and head upgrade in the future so I will be able to have a good look inside at how well it works.
    Will post up on how I go with it.
